Results 1 to 10 of 100
    Senior Member oddpedestrian's Avatar
    North Carolina
    Well I finally decided to switch out my Lis for ALP.
    I am getting prepared to receive the ALP and have a few questions.
    1. Can parking aid be completly deactivated without deactivating jammimg?
    2. How long is the power cord coming from CPU?
    3. When I update firmware, control module, and change settings can I put all three files on the usb flash drive and then the ALP automatically load all settings at once or will I have to go through the setup process one file at a time?
    From what I am seeing it will do them all at once but you have to continue power cycling the unit for each file to upload. Is that correct? Does it matter which order in list I have the files on the flash drive.
    Thank you guys in advance!
    Going to dark side now kasher?
    LEOOOO's come out to plaaaaaaayyyyy.
    BYE BYE LSP HELLLOOOOO ALP
    REDLINE REDLINE REDLINE, CAN NEVER GO WRONG WITH A REDLINE.....BY THE WAY DID I TELL YOU I HAVE A REDLINE?
    WAZE
    PRECEDENT DETECTORS:
    9500ix
    VALENTINE 1
    WHISTLER CR90
    Quote Originally Posted by oddpedestrian View Post
    Dark side?
    I just wanted most cost effective way to upgrade. Even if LI releases update it will have to be new hardware to keep up and I decided it was better to sell now while value of LI is still good and just get ALP.
    I may end up being wrong but even so I will have a good jammer and wont have to worry about upgrading for a while.
  3. The Following User Says Thank You to kasher1979 For This Useful Post:
    kimberdan (04-14-2014)
