Results 1 to 10 of 84
    When you did the baseline run, was it tape on + no Veil, or was it no tape + no Veil? The baseline run wasn't shown in the video, so I can't tell. Your description seems to suggest it was no tape and no Veil (and if this is the case, how do you know whether the tape or the Veil was causing the slightly reduced PT distance?).
    Baseline run was done without tape and no Veil. The first two passes were done with very little tape only covering the Logo, Badge and turn signals. I can only assume it was the Veil reducing the distance as the first two runs were mostly a result of Veil on the head lights and fog lights. This should be easy enough to replicate with tape only.
    That would be a very interesting test to see, as it could establish a new baseline (or not).
