Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 93
  1. #81
    Senior Member tawwwd's Avatar
    You might have had one long alert but if they released the trigger and pulled it again the second pull would register as another hit but it might have been the same encounter so you did not realize it.
    Could be the case. All 3 alerts seemed to go the full 4 sec JTK then blinked green.
    I got one of the overpass hits on camera.
    http://vid1052.photobucket.com/album...psbuiz9vfh.mp4
  2. #82
    Senior Member oddpedestrian's Avatar
    North Carolina
    Quote Originally Posted by tawwwd View Post
    I can't see this could you upload to YouTube?
    BYE BYE LSP HELLLOOOOO ALP
    REDLINE REDLINE REDLINE, CAN NEVER GO WRONG WITH A REDLINE.....BY THE WAY DID I TELL YOU I HAVE A REDLINE?
    WAZE
    PRECEDENT DETECTORS:
    9500ix
    VALENTINE 1
    WHISTLER CR90
  3. #83
    Quote Originally Posted by oddpedestrian View Post
    Sure
  4. The Following 4 Users Say Thank You to tawwwd For This Useful Post:
    modsl55amg (03-23-2015), oddpedestrian (12-13-2014), Qui-Gon (12-14-2014), RedRocket (12-14-2014)
  5. #84
    Oct 2014
    Shreveport, LA
    Sure
    lol, OT, but when I saw the Youtube preview image, I was like hmm that looks like AB!
  6. #85
    Quote Originally Posted by hussein View Post
    Haha!
    How could you tell?!
    I think this place is the speed enforcement capital of the universe! I believe these vans are the dragoncam laser ally? I really wish there was a way to confirm a jam from our end!
  7. #86
    The netherworld of the Force
    Haha!
    Your confirmation is the BEEEEEEEEEEEEEEP you hear!
    STi-R: the ORIGINAL!
    AL Priority TRIPLE
    ALP Hi-Fi Module
    ALP Add-on wish list:
    2 more heads
  8. #87
    Oct 2014
    Shreveport, LA
    Haha!
    If your sensors are the same height, depth, level with the ground, 18" apart, you should be good. No tickets is a good delayed indicator, heh.
  9. #88
    Ohio
    Looks like I might be upgrading to rear heads soon after seeing this
  10. #89
    theyre perfectly straight and I have coverage of my plate and all the chrome on my bumpers.
    They do point up just a little because of the rake on my truck (back end site 3/4" higher than the front). I was going to adjust it and make it flat but I figured that might be better because of the angle on the overpass shots. Seems to work so far.
  11. #90
    South Jersey
    Your AL Priority is still a virgin... Here are my stats:
    Device information
    Serial number XXXXXXX
    Firmware version 4.2.2
    Region North America
    Power Cycles 96
    Control Set FW version 2.4
    Control Set HW version 1
    Settings
    Audio Volume 3
    Parking detection range 3
    Silent Power-up Disabled
    Dark Mode Disabled
    Parking enabled sensors Front1, Front2, Front3, Rear1, Rear2
    GPS Antenna Enabled
    PDC Speed Limit n/a
    Working mode Parking and Laser Interference Defense
    Pro mode Disabled
    LID Speed Limit n/a
    Radar Antenna Model STIR+
    Radar Settings X, K, Ka
    LID Time Unlimited – Test purposes
    Specific LID settings
    Vitronic Poliscan
    Speed scanner Enabled
    Unicam Camera
    Section speed control All sensors ON
    NJL SCS
    Speed-laser Enabled
    Riegl
    Speed-laser Enabled
    Trafic Observer
    Stalker
    Speed-laser Maximum Power
    Alerts by Source Speed-laser
    Marksman and UltraLyte 50
    Atlanta SpeedLaser Stealth 2
    Kustom ProLaser 1 2
    Kustom ProLaser & ProLite 39
    Redspeed SpeedGuard 0
    Riegl 0
    Stalker 156
    LTI Truspeed 76
    Unipar - SL700 0
    NJL SCS 101 & 102 0
    Jenoptik – Laveg 0
    Leivtec XV 2 0
    Laser Ally 240
    Error Sensitive Lasers
    Jenoptik LaserPatrol 0
    Jenoptik TraffiPatrol XR 0
    ProLaser 2 & Atlanta SpeedLaser 8
    Speed Section Control
    Camea - IR Camera 0
    Speed Scanner
    Traffic Observer 0
    Vitronic Poliscan 9
    Radar
    K-band 0
    Ka-band 0
    X-band 0
    POP 0
    Tom (BRD),
    Regarding the "Print Settings & Use Statistics" feature of the ALP system:
    1. Is the firmware upgrade for this feature supposed to be installed into the ALP system when the other files are installed via a Flash Drive, e.g. (Uxxxxxxx.bin, UCSTHIFI.BIN, VOICEPAKCK.ALP, setup.alp), in order for the system to collect/store data for later retrieval?
    2. Or is the "Print Settings & Use Statistics" firmware supposed to be loaded onto a Flash Drive, then inserted into the flash drive port EACH time the owner wants to retrieve information from the system that the "Settings & Use Statistics" feature provides, and writes onto the flash drive while it is inserted?
    Thank you in advance for your advice.
