Could be the case. All 3 alerts seemed to go the full 4 sec JTK then blinked green.
I got one of the overpass hits on camera.
http://vid1052.photobucket.com/album...psbuiz9vfh.mp4
modsl55amg (03-23-2015), oddpedestrian (12-13-2014), Qui-Gon (12-14-2014), RedRocket (12-14-2014)
theyre perfectly straight and I have coverage of my plate and all the chrome on my bumpers.
They do point up just a little because of the rake on my truck (back end site 3/4" higher than the front). I was going to adjust it and make it flat but I figured that might be better because of the angle on the overpass shots. Seems to work so far.
Tom (BRD),
Regarding the "Print Settings & Use Statistics" feature of the ALP system:
1. Is the firmware upgrade for this feature supposed to be installed into the ALP system when the other files are installed via a Flash Drive, e.g. (Uxxxxxxx.bin, UCSTHIFI.BIN, VOICEPAKCK.ALP, setup.alp), in order for the system to collect/store data for later retrieval?
2. Or is the "Print Settings & Use Statistics" firmware supposed to be loaded onto a Flash Drive, then inserted into the flash drive port EACH time the owner wants to retrieve information from the system that the "Settings & Use Statistics" feature provides, and writes onto the flash drive while it is inserted?
Thank you in advance for your advice.
