So after swapping "Ports" the same Sensor (Driver side) is still silent...correct ?
Now,you need to check the DIN connector for the Driver Sensor to see if there is a problem w/ it.Unplug the Male & Female connector from each other & carefully look at the pins on the "Male" connector (the Female conn. is on the Sensor wire side).
Are the Pins ALL straight & ok ???
Be careful plugging them back together...there's a small "detent" to align them BEFORE pushing them together !!!
This is important so you don't bend/damage the Pins.
Correct after swapping the same one was still silent.
I did unplug and replug connector but I did not really look to see what the actual pins in there looked like.
