Results 1 to 8 of 8
  1. #2
    Quote Originally Posted by Keithtastic13 View Post
    Wanted to introduce myself to all. Have been lurking for a few weeks looking for options to integrate with the ALP. I spend a lot of time in VA, so RDD's are an issue. Would be curious to know if anyone has found a way to integrate 2 antennas w/ an ALP system if I only need to use one at a time.
    I have an stir plus m3 that was purchased from an RD member recently, but would also like to use either a netradar or a radenso HD+ as the other for the bsm filtering when I'm not in VA, but I'm still comparing those two on a performance vs rdd detectability range basis.
    As you can see - I still have a lot of research left to do.
    Thanks all!
    Keithtastic
    Welcome to the Forum.
    You can run the M3 completely independent all by itself. NETRADAR & AL-P can be run integrated outside of VA... this pair both can be "detected" from training & by equipment VASP use today.
  2. The Following 2 Users Say Thank You to RedRocket For This Useful Post:
    curmudgeon (11-02-2016), Keithtastic13 (10-31-2016)
