Ok, we can use this, but don't use the Laser Tester,the output is to wide & not useful to draw conclusions for which sensor or cable is the bad one.
Use your hand instead- by placing it close (about 10mm) to each one, see if you get U-boat "ping" sound from each Rear sensor.
