Ok so after playing around with the DEMO mode in the app prior to purchasing the BT module, I've come to the following cons that have made me think twice about going the BT Module route. I'm posting here to see if any of my concerns are incorrect. I know that ALP is currently working on a newer module for release in 2016, so wondering if we can expect additional improvements with that release
1) Essentially iOS users need to keep their phone constantly on with the app on screen in order to reduce time for JTK. Of course you can be in another app or the phone can be in sleep mode but this slows the reaction time as one would need to tap the notification to open the app and then double tap again for JTK? Even worse, if your phone is sleeping while music is playing and you need to JTK, you have to enter your passcode (if you have one set) on your phone to unlock it and then get to the app if it isn't the first thing it opens?
2)you can have an older phone that is dedicated to just being your ALP display in vehicle, but if this is not the connected to your car via bluetooth (because your actual working phone that you take calls on is connected) then you cannot hear the alarms over your car audio
I'm not big on setting a jam time vs. using JTK so having that quick and easy accessibility to JTK is important.
