Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
    Very nice i like it.
    LI, NY
    If your phone is not connected to the Bluetooth, will the jammer still work? There are times that I may run without the phone, but I still want alerts with the control unit.
    Quote Originally Posted by hitechrr View Post
    The Bluetooth module replaces the control module so if you are not going to run with your phone then you need to plug the control module back in. This can be easily accomplished with a RJ45 male to RJ45 female connector. See this post: http://radarandlaserforum.com/showth...view-by-Mirage
  4. #14
    Maybe in the future but at this time you can only choose to use either the Control Module or the Bluetooth module since they both connect to the same port. If you do not have your phone with you then you would need to unplug the Bluetooth Module and plug in the control module to use the system. I am looking into possibly creating an RJ45 switch or something similar that would allow you to plug in both RJ45 ports and switch back and forth without having to manually switch the plugs.
  5. The Following 4 Users Say Thank You to BestRadarDetectors For This Useful Post:
    JohnBoy (12-30-2013), RigToFly01 (12-30-2013), Salty (12-30-2013), Yellowcab (12-30-2013)
  6. #15
    Something like these might work for a short term solution. I ordered a few and will test when they get in. As long as they are manual pass through switches I cant see it not working but they are made and ship from China.
    http://www.ebay.com/itm/Network-AB-2...-/190684396308
  7. The Following 4 Users Say Thank You to BestRadarDetectors For This Useful Post:
    JohnBoy (12-30-2013), Mirage (12-30-2013), shanetrainST (12-30-2013), winterbrew (12-30-2013)
  8. #16
    Georgia
    This looks promising.
    My toys:
    2009 BMW 328i Convertible
    SmartRadar by Escort
    Check out My Install
  9. #17
    LI, NY
    That looks like it should work.
  10. #18
    LI, NY
    You can try this one from a usa seller. http://www.ebay.com/itm/New-2-Ports-...item1c318173c0
    You can buy a 1ft cable to hook the box under the dash. http://www.ebay.com/itm/1ft-Cat6-Eth...item1e82d661e6
  11. #19
    I saw that one but I felt it was too big in my opinion. I have plenty of tools and cable to make my own custom cables. I also prefer flat black cable in my installs and I am not sure if that Ethernet cable would be a straight through.
  12. #20
    Yes, the Chinese one looks suitably small - I've just taken a punt on a couple, but looks like the earliest they'll be here is 14th Jan !
