Results 1 to 10 of 33
    Member REVNURAZR's Avatar
    Perth, Western Australia
    very nice install, look forward to the testing
    Back tomorrow, will need to dig up my dash camera and go for a drive.
    Nice - did you get the ProDB direct from USA, or the distributor here.
    It probably won't affect you too much on the rear, but it was found that lidar from a front facing poliscan or handheld can make the ProDB false prematurely. The guy in this thread below had it false on him a second or two early before he approached a front facing poliscan, and then got flashed and ticketed;
    http://radarandlaserforum.com/showth...DB-Test-Result
    The local distributor fixed this by applying some IR filtering film over the sensor. That was shown to fix the lidar/IR falsing issue
    This is the one we're waiting on - the Mk II NoPhoto ;
    No one's had a production model to test yet, but there's been several videos showing it reject falses from handheld lidars etc
    I got it from an Australian distributor here in WA, from what they have told me there is only 70 cars including mine in WA that have the PRO DB installed. They haven't had a complaint yet.
    I went back there to verify the install and ensure the LI was programmed correctly, I downloaded the software and enabled the optional parking sensor switch which I have wired up and put in a "safe" place inside the vehicle should I need to prove it operates as such to the fuzz.
    They tested the LI with a Trucam and also tried to set the Pro DB off with it, but it wouldn't flash.
    Jam time is set for 5 seconds and 20 seconds re-boot time.
    The No-photo looks pretty good, a lot more slimline and subtle opposed to the Pro DB. I'll be sure to inquire about the release date in AUS.
    I'll get some pictures up tomorrow and hopefully a video or 2
    Cheers
  2. The Following 2 Users Say Thank You to REVNURAZR For This Useful Post:
    dinkydi (10-29-2015), winterbrew (10-29-2015)
    Quote Originally Posted by REVNURAZR View Post
    Nice - sounds like they definitely got the initial falsing issue sorted now then
