The key with using 2 heads is to not place them on opposite sides of the car. (For example next to the head lights and leaving the center mass open) If the car is an average size car and your sensors are centered but around 18" to 20" or so apart you will be fine but if you have the sensors spaced 3ft apart you will get close PT's Use the photo's from past testings as a guide or if you have questions post up some photos and we will give you the best placement ideas.
Still getting hip to all the CM lingo, what is PT? Pass Through? Also what is JTK? Jam Till Killed? I know JTG is Jam To Gun lol.
