Page 13 of 15 FirstFirst ... 31112131415 LastLast
Results 121 to 130 of 145
  1. #121
    Name:  Tested and Approved.jpg
    The results are posted! http://www.raletc.com/2014/09/raletc...sting-results/
    Note to Specifics and RigToFly:
    Did you guys keep sheets from your runs? I appear to be missing some of your results.
  2. The Following 9 Users Say Thank You to Mirage For This Useful Post:
    Christoph_Kohl (09-25-2014), dinkydi (09-25-2014), FJR1300 (09-25-2014), fox in the hole (09-26-2014), itwasntme (09-25-2014), NYSpeederPVM (09-25-2014), Radarrob (09-25-2014), RigToFly01 (09-25-2014), Salty (09-25-2014)
  3. #122
    Moderator Salty's Avatar
    Nice layout and commentary.
  4. The Following User Says Thank You to Salty For This Useful Post:
  5. #123
    Connecticut
    I agree. F*CKING FANTASTIC JOB! I sent you specifics results. the only thing you were missing from me was the XLR which was JTG/JFG.
    PowerUCC Panorama G DashCam
    --> RALETC TESTED! <--
    Install
    Prius_C_Install
    Testing
    April_4_2014
    April_13_2014_RALETC_MEET
  6. The Following User Says Thank You to RigToFly01 For This Useful Post:
  7. #124
    FL
    You mentioned that a 3rd head should be on the same plane as the other two. Would this mean that all dual front or all dual rear heads should also be on the same plane?
    I set up my rears with the left rear slightly higher than the right to try and account for different angles between level and overpass shots. BRD thought this was fine at that time, has further testing shown this not to be the case any longer?
  8. #125
    you are a special case with a small footprint I probably wouldn't recommend that for you. BRD and I talk about this stuff quite a bit so if he told you to do something then I would stick with it.
    With respect to this test the user had a triple setup with 2 heads on the upper part of the front facia and 1 head in the lower portion of the grille. This is not optimal because you increase the risk of cross talk between the sensors.
  9. The Following 2 Users Say Thank You to Mirage For This Useful Post:
    FJR1300 (09-25-2014), itwasntme (09-25-2014)
  10. #126
    nothing is perfect , all results very nicely laid out thanks again ,well done by all
  11. #127
    FL
    Gotcha, I do have my tag light housing that protrudes between the rear sensors.
    It wasn't so much that BRD advised me to do that, as I thought about it and asked if it was okay, just didn't want to give the impression that conflicting advice had been given.
    Thanks for the reply.
  12. #128
    Great job on a very easy format to read results from.- Time to finally rest & kick back now,it's Miller time(or higher octane ) in the Lone Star State.
  13. The Following User Says Thank You to RedRocket For This Useful Post:
    specifics (09-25-2014)
  14. #129
    Senior Member specifics's Avatar
    NY
    I only made the few runs before everyone showed up that was posted..... I was having too much fun in that Altima... lol Those results are awesome and well done... very professional and easily comparable.....
    “There are three musts that hold us back: I must do well. You must treat me well. And the world must be easy.”~~~ Albert Ellis
    V1 3.893; YaV1
    V1 3.813 Original Version
    ALP Dual
  15. #130
    Connecticut
    Quote Originally Posted by specifics View Post
    Ya, sure you were!
    Install
    Prius_C_Install
    Testing
    April_4_2014
