I support your wish , under alert i dont think to scan the little led , i rather scan to find the
threat ...it would be quite simple to implement a different sound as they already have the information.
HiFi is a solution in view.
Alp connect : i dont like to pass by a phone to get my infos .
I tried to get a get a photocell to differenciate the color ...no success.
When using the control pad and you are hit from the front or rear it has a distinctive solid tone with Only different colors for front or back! How about when you are hit from the front you get a say a real fast audible chirping or solid tone and for a rear hit get a different tone--
that way at the exact second you know where you are hit at, and either to apply heavy brake(front hit) or emergency handle pull or whatever(rear hit) so you dont activate your brakes and tip off the PO-PO! Just a thought?
