Results 1 to 10 of 24
    '' 6. This LED will flash as you are being targeted so if the user cycles the gun (ie off trigger on trigger)
    then you will see that in the LED. ''
    Can we say then : when the led is flashing , the Alp is jamming ?
    It would be the equivalent of the led flashing on the Li switch ?
    Thanks.
    Thanks.
    Yep exactly the same.
    Quote Originally Posted by mirage View Post
    Fine , one step further : after i Jtk , would i see the led flashing when the cop keep shooting ?
    I guess no because the Alp turns to parking mode ...though i would like to be so .
    Mirage would you verify ?
