Results 1 to 10 of 24
    Senior Member TurboDriver's Avatar
    Michigan
    I use the external LED (up on dash) and use dim and dark modes so only the controller blinks (dim). So question is how long will the LED blink when targeted if not in Pro mode? Is there a default time, kind of like how a RD has a hold time even after the signal goes away. Example -RedLine is somewhere around 8 seconds or so even if radar was only 1 second, so if laser hit of 1 second (not in Pro mode) how long will ALP alert?
    Go Like Hell, you'll get there.
    RedLine
    Bel 300
    X50 Black
    ALP Dual
    Quote Originally Posted by TurboDriver View Post
    I'll have to try it. To be honest I always ran it in PRO mode after I understood what it did, but I've been running the bluetooth for a while now so I'll have to plugin the controller and test it out.
  3. The Following User Says Thank You to Mirage For This Useful Post:
    dinkydi (03-30-2014)
    FL
    This is what I have been wanting to do, I must have missed how to do this because both the controller led and remote respond in unison when going to dim or dark when I tried to set it this way.
    Can you tell me how you got the remote led to stay dark while having the controller led still blink (confirming system is on)
    Thanks
    Sent from my SAMSUNG-SM-N900A using Tapatalk
