ALP Sensor group firing question. ( Rear Set-Front Set)
ALP 5 sensor set up.
background for this question.
I have done a bunch of AutoCad drawings that show all the angles of incidence that i may get a alert from, during this process we have overlapped the sensors array/FOV and adjusted the install angles of the sensors specifically to give best protection against the German revenue generator for my specific truck. ( F150 Raptor 4 door)
during this process we found that the best coverage was to have 5 sensors located in different strategic places, one of those locations was in the wing mirror facing forward at an angle of 24 Deg. ( yes, side facing)
During this logical reiterative process the question arouse as to what happens when you get a hit and only one sensor receives the attack.
From a logical POV if the system is labeled such that Front-Rear then i would assume that if any of the single front 3 sensors gets hit then all 3 sensors fire back for security regardless of which one took the initial hit.
However, what happens if we install all 5 sensors at the front and one of the two labeled "rear sensors" receives a hit, will only the "two rear" sensors fire back? ( based in the logic above i would say yes, but i hope im wrong.)
If this is the case then i need to think about which sensors get plugged into which socket based on their physical location on the truck.
If they all fire back regardless then it does not matter which sensor gets plugged into which socket.
J.
