http://www.raletc.com/2014/09/raletc...sting-results/
Compare the Laser Interceptor Vehicles.
OK thank you Mirage.
So after reading it...It could have been the frontal area and separation of the heads (lack of crosstalk) that caused the JTG back to back performance...it could have been the Veil.....it could have been a perfect installation....all according to the author there.
I firmly believe cutting down the reflectivity is a plus. No doubt in my mind. The question in this thread and the purpose of Mirage's test Sunday are simple. Does Veil perform as advertised? Yes or No. Fox in the Hole runs are inconclusive concerning Veil. As a LI user I love his results....but I do not see anywhere in the test nor the writeup that I could contribute his success to one particular item or product.
Bottom line for me is I wish like hell Veil worked. I have no personal ax to grind here. If it worked and could be definitively proven to work I would slap that shit all over the GT500 and the GTO and go like hell. But we all know the answer to that wish.....DENIED.
If wishes were horses
Then beggars would ride
If wishes were fishes
We'd have them all fried
This is why I wish we had HUD on those runs and why I requested HUD video on any product testings. Of course this is not possible due to time in regular user meets but for product testing it needs to be done. There could be many reasons for those results and the results were inconsistent from one run to another. Its virtually impossible to see why that run was good... Did the LI's work on that run and catch the Compact in an pattern it liked? Did G4 (The car was slopped with it) help? Did the shooter stay on target? Its impossible to know without seeing the video to answer many questions.
Based on the installation, the model of jammer and car, I normally should have gotten some PTs. Also from he feedback I was getting from the lidars I can say with certainty that Vei G4l greatly improved the performace on that vehicle. Will G5 have the same performance as G4, I do not know. If I was Fox in the Hole, I wouldn't remove the G4 unless he wants greater output from his headlights.
I have a different take on the effectiveness of Veil G4 and the Fox In the Hole car. First of all, if you look at the results between Christopher Khol (Also LI 8.18) and Fox in the Hole you will see there was very little difference between them other than Stalker, but that also is an older gun that is no longer in use. If we assume < 200 is considered JTG then:
Gun Christopher Khol Fox In the Hole ProLaser IV JTG JTG ProLite JTG JTG ProLaser III JTG JTG Stalker LR JTG JTG Stalker XLR JTG JTG LTI LR B JTG JTG Truspeed JTG JTG Truspeed S 244 JTG Truspeed SX 584 JTG Truspeed LR 287 306 DALA #4 JTG JTG DALA #5 IPT IPT Compact #1 512 310 Compact #2 651 IPT
When you compare them side by side they are very close. Keep in mind the Truspeed SX was tearing everything up that day so it was luck of the draw as to whether you got a PT. Both of these guys had at least one run against COMPACT #1 that was JTG. We also had the same results on our test car on the previous day.
https://www.youtube.com/watch?v=89Ij6cPzELc
In addition, during my pre-testing or 8.17 I had nearly the same result on my own car.
https://www.youtube.com/watch?v=O-9Cn5MDrss
I was also shooting that day and I couldn't tell a difference in his car or Christopher Khol's car. It would still be speculation that Veil G4 was contributing anything to the performance of the vehicle and if it was ever determined to be a contributing factor it was MARGINAL at best as the results are too close to call.
But in a passive counter measure situation there should not be much of a variable between guns. IE.....laser is laser and if I say my stuff will absorb it in a passive environment then what gun and pulse rate I shoot you with is irrelevant. And the results should be much more consistent than a active solution
One of you big heads set me straight but that is how I see it.
