Results 1 to 10 of 14
Thread: Tx advice
    Leave your regular sensors where they are and put the TX Sensor below (RED) and you will be golden. 2 Regular Sensors will work against mostly everything but the newest round of DragonEye guns would require 3 sensors and the TX fits the bill perfectly.
    FYI... Here is my wife's install:
    Name:  GL450-TX Sensor.jpg
    Member angrypenguin's Avatar
    Oct 2016
    Thanks. Can you please share how you ended up mounting the tx head? That's my main struggle atm is trying to figure out how best to mount it b/c the mounting bracket encapsulates the entire tx head. It looks like you're using double sided tape?
    Would it be a really bad idea to put it on either of the blue lines in the pic in my post? That seems easiest to mount
    Thanks!
    Quote Originally Posted by angrypenguin View Post
    Thanks!
    I built a small mold with epoxy to make the area flat under the logo and then simply used 3m Molding tape. You want the TX Sensor in the center of the vehicle and there is no better place.
    angrypenguin (08-19-2017)
    Oct 2016
    Any chance I can buy one of these off of you?
    Also, if I put it at the bottom of the three pointed star, it measures 20.5" off the ground. Any idea if that would cut it too?
    Maybe i'll just get lazy and stop talking myself from blowing more money
    You will have to make your own mount. If you have a installer they can make you a custom mount easily.
