Results 1 to 10 of 40
    Jan 2015
    I installed everything but I am not getting connected via the BT module. I am going to update the control box one more time and see if that fixes the issue. I had an issue a week ago trying to update the control box firmware (some checksum garbage that I dont remember).
    Quote Originally Posted by jakevsnake View Post
    Make sure your BT is wired correctly and that you dont have the wires in the opposite ports. That will prevent you from connecting to BT but the wired controller would work.
    The 'checksum failed' message means you need to make a new config.alp file on the alpupdate.com website and upload that, as its required by the new firmware version for all the new options introduced
    Jan 2015
    Crap, I thought the V3 module replaced the "other" BT module. I think I have the original BT module. It probably wont work, will it?
    There is no new BT module. The V3 refers to the RG3 module needed to connect multiple Net Radar antennas.
  6. #6
    Jan 2015
    Ok, I bought the V2 BT module and it should be here Wed-Thu. I disconnected the control panel to use the BT exclusively for now. I have so many other things Im dealing with that it took me two hours to figure this out. lol
