Results 1 to 4 of 4
    South Jersey
    No.. It's not waterproof.
    Are you correct in stating that the GPS antenna for the ALP system is NOT waterproof ?
    Per another forum member's post, in the ALP GPS Antenna thread, he refers to http://elecomes.com/article.php?id=31 in which the manufacturer states that the GPS antenna IS waterproof.
    Is this Elecome GPS antenna the GPS antenna I purchased from BRD a couple weeks ago ? My pro installer needs to know if it is waterproof, or if it is not waterproof, so that he knows if he can install it outside the car's interior (behind front plastic bumper cover).
    Thanks.
    Thanks.
    Antenna is designed to be mounted on or in the dash. It also comes with a 9FT cable which would not be long enough to mount in the bumper. Have you installer install in the center dash panel.
