For now I use the Blinder 905 4 had...
I have Lidars and Radars, and 3 RDD
I intent to buy the ALP, as I think its the new king...
My toys:
2009 BMW 328i Convertible
SmartRadar by Escort
Check out My Install
.Danger - OPP uses "LaserAlly" Lidar guns,HP-905 doesn't alert to newer firmware Models of this Mfg.
You are 100% correct, I learned that this Lidar was recently entered Ontario, I just removed the Blinder 905 from my car, and I heard: the traffic cops in Ontario are not as forgiving as the traffic cops in Israel, as I understand "the Alp is the best solution to that Dala pollution...." I still worry about jamming code showing on the DALA and on Laser Atlanta, as I understand even the Alp cannot avoid that...
Jam codes on the SpeedLaser Atlanta shouldn't be much of a concern even in the Stealth mode.
The LaserAlly is much more worrisome however.Yes,it is a problem & the OPP are very strict.Also,you should know the OPP will shoot you in the back...after you have passed by them.
I have seen the LaserAlly display a jam code even though the target car DID NOT have a jammer.I believe it is caused by the HL's (Headlights) on some cars but not all HL's cause this false jam error.
max (12-19-2013)
