Try loading only the Firmware & Setup file. When the VoicePak is on the same drive it will update the Controller & Voice Pack first before the firmware. If there is an issue with the voice pack or controller firmware it will stop there so try bypassing them and only load the setup file and the firmware file. Also, The serial number you supplied me was sold to a dealer, He let you pick up your vehicle without the system running properly?
