Results 1 to 10 of 24
    AL Priority is 100% of the time a parking sensor but if it detects interference it will go into defense mode. (You can see this from the video as its idol in parking mode but as soon as its hit with laser it immediately reacts) All Sensors will pulse the parking signal even if you have parking mode disabled. That is what the test above was to determine. In any case you are not talking about a hot sensor but it is warm to the touch but warm enough that in some peoples case it might keep ice off of the heads. I will surely test this when it gets cold enough here.
    Ok so if (All Sensors will pulse the parking signal even if you have parking mode disabled) what is this actually doing, Im assuming nothing if parking sensors are disabled, which means you have no parking sensors activated and no parking aids available correct? I have plenty of cold and ice lol, just no ALP's yet
    Correct the heads are designed as parking sensors and if you turn off the function in the CPU the heads will still operate as normal but it will not alert you if you are too close to an object.
