LED will immediately change to acknowledge the Kill and the alert will play out until the Gun ID. Also remember if you are using the HiFi to put it in detailed alerts if you want the Gun ID's.
I run Pro Mode. As it stands now, the LED does not acknowledge the kill, but instead indicates whether I am being targeted or not, and the JTK acknowledgement is audible only. How can the LED be used to acknowledge the kill, if it isn't flashing in the first place (say I pick up scatter and I am no longer being targeted)?
