Results 1 to 10 of 47
Thread: HiFi installed
    Basically yes but the buzzer is annoying imo. It was much better before as you could watch the led and still hear the alert. well at least on the BT module. The hifi is new. So basically you can tell if you are being targeted vs catching a stray reflection. Now you can't tell what the gun is because you will have JTK before it finished. I said I would stop complaining so this is it.
    Pro Mode was always with a buzzer sound which changed depending on the strength of the incoming signal. The buzzer sound changes and you can hear if you are the target or just picking up scatter verse a direct hit. You are just used to using ALP Connect and the Ext. LED with ALP Connect in pro mode still only illuminates when you are targeted.
    If you are the direct target even in Pro-Mode it will give you the name of the gun if they stay on you. The Buzzer only kicks in if they re-pull the trigger or sweep away and come back to you.
  2. The Following 4 Users Say Thank You to BestRadarDetectors For This Useful Post:
    Clint Eastwood (12-29-2014), curmudgeon (12-29-2014), modsl55amg (02-28-2015), Tman (12-29-2014)
