Mine was just delivered! On time with no detailed tracking needed.
No plans to install for a few days. Too busy right now with the family. Will do it when the kid returns to school.
Soo... My HiFi update was not very smooth...
After updating all the firmware and attempting to power on the unit the first 9 or 10 attempts ended like this...
I then attempted to reload firmware (which it skipped I assume since it was the same version) and then this happened 3 or 4 times...
I again attempted to reload the firmware (skipped again) and it finally turned on properly... then it died during my first test. Note that I was still shooting with my tester for a few seconds after it died. I clipped the video since there was about 30 seconds of nothing as I tried various things assuming the LI tester was having issues while standing in front of the car lol
Redline Ka 5,6,8,9
ALP Quad 2F/2R
Itronics ITB HD100 SP 1F/1R
Seems to be working now...
Redline Ka 5,6,8,9
ALP Quad 2F/2R
Everything is working fine. The buzzing noise is because you are in pro mode and are getting hit with a second shot.
Most likely you did not let the update complete when updating the voicepack initially. It takes much longer to update than firmware.. Almost 4+ minutes.
The update did take longer than the previous ones. I think the system died during the update after it attempted to reboot itself and the sound was somewhat distorted as it died. So you are probably right in that something likely didn't finish updating. I am just glad it's working well now. This may be a sign that I should use a newer flash drive for updates even.
I am familiar with the buzzing in the last video as it is very similar to the standard control set buzz during an alert in pro mode. I was just testing the various alerts for front/rear and getting use to how it sounds when being shot multiple times, short shots, longs shots, etc.
Redline Ka 5,6,8,9
ALP Quad 2F/2R
Just ordered mine from Alex at KMPH. What steps need to be done after swapping out Control Modules? I'm thinking a new setup, bin and UCSET file are all that's needed, other than the HiFi update with voice park files.
ALP Quint - HiFi
ALP Triple - HiFi
STi-R Plus (x2)
Installing now, gunna make a video too![]()
9500ci BS 2/5/8 / RDR Off / X Off / K Off (TSR useless!)
ALP Quint | V1 3.894 / YaV1 User
LUKAS LK-7900 | Waze
2011 Ford F150 SuperCrew 5Star Tuned
Laser: UltraLyte LRB | Atlanta SpeedLaser II / Radar: Stalker ATR Ka
Having issues with it going blue, then blinking red, then turning off when the USB isn't plugged in, and my settings didn't transfer. Re-grabbing a settings file and trying again, though the setup.alp I got it to save with the stick in says its in LID mode, it didn't alert or blink at my PL3, will update shortly.
Please remember you need to update the cpu firmware and then both the control set firmware and add a voicepack file.
