Results 1 to 4 of 4
    FL
    I have an ALP quad on my bike, absolutely must have two heads on each end to defeat VRP/VRRP lidar. If you aren't concerned with those, one head on each end Wil take care of the regular lidar guns.
    The 9500ix will require the SR10, which is about $170, plus the SMH10R headset. (If you go with Sena). However if you go with an RD that integrates with your smartphone via bt, like the V1, then you can eliminate the need for an audio bt transmitter (SR10).
    I used a brand new 9500ix earlier this year setup this way; it all worked but the unit that I got absolutely sucked in range compared to my V1. YMMV of course
    I think you can use the live cord to get your Escort detector audio to your phone though? Check with the Escort gurus here, BRD will know for sure.
  2. The Following User Says Thank You to FJR1300 For This Useful Post:
    tawwwd (12-15-2014)
    Senior Member tawwwd's Avatar
    We have tons of VRP/VRRP lidar here so looks like Ill be buying another quad setup!
    More concerned about that than Ka detection. The 9500 should be fine for our area. I found another bluetooth transmitter/speaker to use on a bike forum that someone else did with another detector setup.
