Problem is its not a false alert. A false alert to me is a false from the sun, etc. and the ALP does an awesome job at eliminating those. The LCC adapter is designed to allow people with vehicles to run Laser Defense. Other systems might seem to be working in these vehicles but as the Vehicle is sending its signals the Jammers are not defending. This will be the first of its kind so the ALP knows when the vehicle is sending out interference and also it will keep monitoring anything new incoming at the same time. The ALP has the least false alerts of any system and they are working on ignoring the rest. If you are not in an area that uses Poliscan turning it off will basically eliminate any false alerts. I keep it on any see a false at most 1-2 times a month.
