Only problem is extension cables would go on the opposite end of the cable and require re-running those wires. In the future always start at the control box and run the wires to the rear this way if your short you can just add the extension. You can get a coupler and a straight wire but AL can not guarantee the connection. AntiLaser uses very high quality shielded and weather proof cables and a coupler and extension cable might might degrade the signal.
