How are you measuring it? If you measure it relative to ground, it'll always be zero volts. You should connect the + lead of your voltmeter to a 12V source and the - lead to the mute wire. Then the meter should read 12V when the ground (mute) is active and 0V if it isn't.
It should active when alerting (jamming).
