Results 11 to 20 of 22
    That heat shrink ALP provides is some serious stuff, Its much better than black electrical tape as that is not gonna seal it like this stuff does. The sealed connectors are very nice though See I should have waited another week lol
    Senior Member ECMExpert's Avatar
    I yam where I yam!
    Starting tomorrow all units shipped from us with have the new wiring. So yes your unit will come with the new connectors.
    and what about us loyal "early adopters" that PUT a lot of trust and faith in ALP when introduced
    Quote Originally Posted by ECMExpert View Post
    You have had the best protection from the first day you purchased it and you should be proud of that.
  4. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    kcsr (04-15-2014), RigToFly01 (04-15-2014)
  5. #14
    I never received any shrink tube with my heads only with one extension cable.
    But now this is pointed out I might just use some electrical tape to seal the joints.
  6. #15
    It comes with every head in the box. Look in the bottom of the cartons there is a zip lock bag with cable ties and the shrink tubing.
    When you purchase an extension cable they also include another piece for the additional connection.
  7. #16
    I got a piece with every cable and head--that's weird you didnt. Go buy some heat shrink because it will do a much better job than tape, I would not even bother with tape.
  8. #17
    Connecticut
    I wondered what that tubing was for. I think I have 3 left. If I don't can someone post a link of what I should buy? I need to do the 3 front heads as those connections are out near the elements. The rear head connections are deep inside the hatchback.
    PowerUCC Panorama G DashCam
    --> RALETC TESTED! <--
    Install
    Prius_C_Install
    Testing
    April_4_2014
    April_13_2014_RALETC_MEET
  9. #18
    All you need is a hair dryer or even a lighter an inch or so away to get it to shrink to an air tight seal.
  10. #19
    Yes shrink tubing is the best. But if something is supposed to be a waterproof connection anyway I always felt that wrapping it well in black tape would suffice. Like my STIR plus connection I seriously wrapped it in some black tape. I will probably unwrap it every year or two and redo for precaution though. Or next time I might try and get some shrink tubing for that.
  11. #20
    I suppose if you really want to play it safe (belt & suspenders) use shrink tubing with the new connectors. Maybe overkill, but, if your install is staying put for a while it certainly can't hurt.
