Results 1 to 10 of 70
    If system is powered on and you insert the USB Memory drive with the firmware on it nothing happens when you insert it? There is no red blinking error code?
    If nothing happens are you sure you also loaded a Setup File with Defense Activated?
    System is powered on, I insert USB memory drive with firmware, UCSET.bin, setup.alp, nothing happens. USB drive light doesn't light up, ALP just blinks normally (blue, one per second), no red error blinking, no multicolor firmware upgrade blinking.
  2. The Following User Says Thank You to Dr86 For This Useful Post:
    modsl55amg (02-28-2015)
