Results 1 to 10 of 13
  1. #8
    Senior Member specifics's Avatar
    NY
    Quote Originally Posted by Qui-Gon View Post
    As the title suggests, I received my ALP DUAL today!!!
    To speed up the installation process, I wired the CPU to power and ground first. Before finalizing where I wanted to place everything, I hooked everything up to the CPU and did the factory reset procedure, then ran the update procedure. After running the update procedure, the LED on the control set was flashing blue (this is good, yes?). I then started placing the jammer heads in the grille, ran the wires into the cabin...then I ran out of daylight.
    Pictures to be placed in the appropriate section later...
    Dude.... you're a fast mover.... Taking your advice this weekend and at least updating the CPU.... Wanted to get to the meet this weekend but my plans have taken a twist..... We should think about something in a month or so in central/west NY for testing....Rochester/Syracuse/Utica region maybe....
  2. The Following User Says Thank You to specifics For This Useful Post:
    Qui-Gon (04-12-2014)
