Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    If you get pulled over, it will most likely be because of your own actions, rather then their skills to detect jammers. A good example is smashing the brakes when you are targeted.
    Few Tip
    Take care in placing your sensors, don't put them on display.
    You can also make fake stickers for them, don't cover front lens!
    If pulled over, remain calm, kill all cm's before Leo comes to door.
    Have your excuse rehearsed..... They are parking sensors.
    If running ALP, have you have a parking only USB ready and on hand to plug in..
    Play dumb is another good one.
    And honestly, drop a gear and come off the clutch slowly if targeted.
    If you have distro braking, come on slowly, they won't notice you slowing down as the rear brakes always kick in at 50% while the fronts are @ 30% until you floor the brake pedal then its 90/90%.
    Don't speed like 40KM over the limit and well, 4 seconds JTK is more then enough. .
  2. The Following 5 Users Say Thank You to beingaware For This Useful Post:
    Abarth695 (03-19-2014), curmudgeon (03-18-2014), dinkydi (03-18-2014), melbVt (03-19-2014), shanetrainST (03-18-2014)
  3. #12
    let them do all the talking
  4. The Following 3 Users Say Thank You to dinkydi For This Useful Post:
    beingaware (03-18-2014), curmudgeon (03-19-2014), melbVt (03-19-2014)
  5. #13
    NYB
    Okay I was picked up once ,
    And it was due a stuff up in the jammer, Hence this was z4 not the trusty Al
    As above says make a usb with Parking detection only and keep it in the car, ( I use velcro to stick it onto gearbox then it's always there if need b)
    Well and if running Al when the GPS feature is enabled you should turn off jammer if driving under 40km then it makes it easy,
    Also recommend installing Cb radio+ antenna that can stuff round sometimes with radar readings so it may help I have done that!
    Option 2= Use the theft lock on the Al aswell this makes it only ever use parking detection only once removed, so no tricky cop using his Al usb to reset yours to Jammer!
    Think Ahead make a story and act it out,
    Example, My friend has number plate flickers, he phoned some government agencies and complained that the media were following him he rings at least once a month and lodges a full written complaint !Then he has copies of letters he written to these different government departments and names, dates of anyone he rang about it,
    Now it has made a great defence for him! Personally I wouldn't do what he done though however my solicitor agreed that he has got a good chance of validating a fair enough reason to have had them,
  6. The Following User Says Thank You to melbVt For This Useful Post:
    Abarth695 (03-20-2014)
  7. #14
    Quote Originally Posted by melbVt View Post
    What was the result of being picked up on the Z4's?
