Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 140
  1. #111
    Is your Control Unit off when you put in the USB stick to load the various files, or is it on and then you put in the USB to start loading the files?
    tried both. both gave me similar light and beep sequence
  2. The Following User Says Thank You to hththt For This Useful Post:
    modsl55amg (02-28-2015)
  3. #112
    Did the unit flash different colors while the firmware updated? Takes around a minute. If you name the file incorrectly the firmware will not update.
    See this link: http://www.alpriority.com/faqs/prope...mware-upgrade/
    And also see this for setup file: http://www.alpriority.com/faqs/proper-name-setup-file/
    I downloaded the firmware file after giving the website my serial number. The file name is Uxxxxxxx.bin so I'm pretty sure it's correct. The setup file is name setup.alp as instructed as well.
    When I plugged in the USB drive and turned on the unit for updating the firmware, I got a red steady light with 3 series of 7 beeps. Does that mean my update succeed?
  4. The Following User Says Thank You to hththt For This Useful Post:
  5. #113
    Quote Originally Posted by hththt View Post
    Error 7 is a firmware update error. Are you using a name brand formatted Fat 16 or Fat 32 drive? Was it empty with only your ALP files? Download the firmware again and try to update it again.
  7. #114
    Yes, mine is a sandisk cruzer micro 8GB that has served me well. I also tried a patriotXT 32GB and a corsair 1GB just now and got the same result? Could it be because I already update the firmware and subsequent update error out? I formatted all of these as FAT32 under windows 8.1
  8. The Following User Says Thank You to hththt For This Useful Post:
  9. #115
    Its midnight here and I can continue trying to help you tomorrow, You can also email support@alg9.com since they are 6 hours ahead of us and its almost morning there.
  11. #116
    UCSET.bin ,which is for the upgrade for the controller, this upgrade goes in with the system switched off insert usb and switch on, i think it needs this before the rest of the updates can go as normal,
  12. The Following User Says Thank You to dinkydi For This Useful Post:
  13. #117
    Thank you. I will get in touch with you tomorrow!
  14. #118
    I believed I updated the controller as per the instruction on alpupdate website. Still no luck
  15. The Following User Says Thank You to hththt For This Useful Post:
  16. #119
    ok just a thought, the usb upgrades gave me a bit of a frustrating time at first,i think Not seeing things happen on a computer , i did a default reset and started all over again , formatting and doing one at a time with 2 usb sticks ,
  17. The Following User Says Thank You to dinkydi For This Useful Post:
  18. #120
    BRD, I came home late today so i couldn't give you a call. However, I made a video just now showing me resetting the unit to factory default, downloading the firmware and attempting the update. The video also shows my serial number so I will PM you the link. Thanks everyone for your help.
  19. The Following User Says Thank You to hththt For This Useful Post:
