Results 1 to 8 of 8
    Feb 2014
    Gold Coast Australia
    Downloaded 1.1.2 after I wrote and saw the great improvements.
    However, when I go to system info, it keeps searching for the firmware and other information listed below it but never gives an answer it just says "reading".
    I cannot therefore see if it has accepted the new firmware.
    It has accepted my set up as it did upload back to the USB and I printed it out, so that works.
    Why won't it read the information ?
    Thanks
    Quote Originally Posted by Abarth695 View Post
    Thanks
    Because you do not have the current firmware on the unit. Download the firmware and follow the instructions on naming it correctly.
    The name of the upgrading file must be: U2234567.bin (where numbers 2234567 stand for 7 digits of the system’s serial number). If you try to download this file more times, your computer may store each new download under a new name, for instance U1234567(copy1).bin In this case you may copy this file to the USB flash drive and change it’s name back to U1234567.bin.
    ALPriority system will not recognize the firmware upgrade file if it is not named as instructed above.
