Mission done , 4.3.6 and 3.2 , checked by the stats .
Résumé of the steps :
Go to : http://www.alpupdate.com/
1)go to '' Firmware upgrade'' , write your serial number @ Control Box update
press enter , do your math , press download , save to pc , file is = u\serial\.bin , go to next step
2) go to ''Control Set update'' , download to pc , save resulting file to pc = UCSET.bin
Take those 2 files and copy them on your usb key.
Go to your system , start it , place the key and wait , it will cycle for less than a minute ,
when all is done it will come back to flashing blue .
I did close and open again the system , tough the 2 files were already installed .
Please correct me if i skip something , when you have done this a few times ,
the routine is very fast .
When the stat file is pulled you should read 4.3.6 and 3.2 on your sreen.
Off Topic
Tom if someone want to revert to a previous version , for a reason or another ,
can it be done ?
