Yes, that's the LED and ALPConnect colours I have with v1 CPU and v1 R/G module with GPS
Tom, The sticker on my ALP Control Unit box indicates: AL Priority - CONTROL UNIT Hw.2 and also YOP: 2014 - 12
Therefore, I would only need to purchase the GPS Antenna from you, and have my installer connect it directly to the CONTROL UNIT, then I can modify my system's Control Box Setup Selections to include the GPS related items. Is this correct ?
I just ordered the GPS Antenna.
In settings there is two areas to set speed (Define PDC) & (Define LID). I set it for 24 in both would this be correct? or do I only set speed for LID? THANKS!
You also would need to adjust:
1. GPS receiver present (Change to Yes)
2. Define PDC SPEED limit (This will prevent parking sensors from alerting if you are in traffic and get close to a car in front of you)
3. Define LID SPEED limit (Speed in which you need to be traveling above for the Jammer to operate)
4. If Radar Antenna is used... Define RADAR SPEED limit (Speed in which you do not want to get radar alerts under)
If there's no GPS signal (say, in an underground garage), how does the system behave vs. the set speed thresholds?
