Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 140
  1. #51
    cheers i relize that know, so when the alp is in parking mode does the plus go to sleep as well (deactivated)
    ALP is 100% in Parking Mode all the time and it never sleeps and will immediately respond to any radar and laser alert all the time.
    modsl55amg (02-06-2015)
  3. #52
    ok thx may have to hide the power switch
  4. #53
    its nice to have radar alerts
  5. The Following 5 Users Say Thank You to shanetrainST For This Useful Post:
    Bear (01-04-2014), dinkydi (01-03-2014), JohnBoy (01-03-2014), modsl55amg (02-27-2015), winterbrew (01-03-2014)
  6. #54
    like the display's showing gun types and k, ka's all on one screen, thats an interesting one the pik ka 33.9, i get quite a few 33,5, but never been fully sure of the source, im still thinking there,s leo hanging around here in qld with that ka , cobra has been suggested
  7. The Following 2 Users Say Thank You to dinkydi For This Useful Post:
    curmudgeon (01-03-2014), modsl55amg (02-27-2015)
  8. #55
    Connecticut
    Imagine how nice it will be, if they can add the GPS coordinates to that.
    PowerUCC Panorama G DashCam
    --> RALETC TESTED! <--
    Install
    Prius_C_Install
    Testing
    April_4_2014
    April_13_2014_RALETC_MEET
  9. The Following 3 Users Say Thank You to RigToFly01 For This Useful Post:
    curmudgeon (01-03-2014), dinkydi (01-03-2014), modsl55amg (02-27-2015)
  10. #56
    who knows , alp has brought cm,s into the 21st century
  11. The Following User Says Thank You to dinkydi For This Useful Post:
    shanetrainST (01-03-2014)
  12. #57
    Keep the ideas flowing... The AL Priority was built based on the customers suggestions.
  13. The Following 3 Users Say Thank You to BestRadarDetectors For This Useful Post:
    dinkydi (01-03-2014), modsl55amg (02-27-2015), shanetrainST (01-04-2014)
  14. #58
    Member Youthan's Avatar
    Dec 2013
    A quick question :
    will the Alp alert to the Osprey , i dont know his prf though ,
    http://www.opticsplanet.com/osprey-l...y-aimshot.html
    The Li alerts by ''unknown gun''.
    Antilaser never used such a method to try to jam, something that don't know. LI do/has this ability. It's not to wise to do it because of possibility to show a jammed code on a gun, like E-07 or E-48. I do remember like LI was selling this product in my country and couldn't to jam properly Traffipatrol XR. The E-48 code was shown at that time. Antilaser newer did something like this, so that's why we never saw such a option to try to jam some unknown gun.
    But there is some small chance to know that there is some new source of laser out there. I use in G9 warning about interference from ACC like Volvo and Infinity. It also works for a new Mazda. This option is selectable in G9 and do not cause a jamming to this source. It only briefly sounds that such a interference occur. What is fun I have one remote control that also sets off my V1 and then G9 also sounds about that interference.
    Tom. I'm curious if ALP also have this option to inform about interference ?
  15. The Following 2 Users Say Thank You to Youthan For This Useful Post:
    dinkydi (01-04-2014), Tman (01-07-2014)
  16. #59
    I have a few suggestions Tom.
    ALP hardware
    1-User defined port config, so all head can be front or rear
    2-User defined Re-arm /defense mode/ reset time (60seconds @the moment)
    3-IR interference check/alarm on start-up
    4-Abilty to Run all ALG9rx Head, without the need for 1 ALP head
    ALPconnect
    1-Firmware updates via Iphone + Firmware update availability
    2-Landscape mode
    3-Ability to change setting live from Iphone
    4-Recent alarms moved to its own separate page + ability to pass-lock it with 4 digits with master key
    5-Simple alarm display on main-screen to display live alarms, then disappear
    7-Radar Frequency displayed in medium text on main screen, then disappear
    8-Bluetooth connection graph changes color to match DB strength (red is bad, green is good) rather than a solid color
    10-Detailed descriptions of the error codes, that appear in recent alarms
    11-A different color car for when the ALP is in warm up mode/first power on
    12-Countdown Reset timer to appear when waiting to go into defense mode
    13-In built Electronic Manual into ALP connect
    14-ALP record mode from ALPconnect, direct send to AL
    15-Abiltiy to connect two ALP cpu's to ALPconnect for people that run 2 systems and define front and rear
    16-Geotag of alarms, export feature to gmaps
    17-Page dedicated for sensor checking
    Long shot
    Voice activated kill mode for Iphone
    Android platform
    Car Voltage Displayed on main screen
  17. The Following 4 Users Say Thank You to shanetrainST For This Useful Post:
    beingaware (01-07-2014), dinkydi (01-07-2014), modsl55amg (02-28-2015), RigToFly01 (01-07-2014)
  18. #60
    nice comprehensive list be good if all that came along,
    also i have the beltronics lead with the press button on to kill false alerts on k band which plugs straight into my magnum, is there any way to link this into the alp plus, by changing the wiring around to add in between the plus and the the module so making it possible to manuallly kill the k alerts
