Results 11 to 20 of 30
    Senior Member Nanook's Avatar
    I think this failure was caused by water from a recent car wash I did...I recall concentrating the spray from the want in that area...soon I will rear the sensor apart and have a look inside
    • '13 ML63 AMG - ALP 5 / STiR+ • '09 ZR1 - ALP 4 / V1 • '14 LEXUS RX350 - 9500ix • '14 HONDA CIVIC EX 9500ix • '16 TOYOTA RAV4 LTD 9500ix / ALP rear x 2 • '14 PORSCHE TURBO S ALP 5 /NET RADAR / STINGER / BLACKVUE
    Okay to here is the results..it's clear the weather sealing failed..
    This is a 4 year in service rear mounted sensor..that from the appearance depicts moisture infiltrating through the lower face/case seam. I do not know if the current units are fabricated the same or if this particular sensor has failed do to a manufacturing defect or design issue...I suppose time will tell if the others follow suit..I'm wondering if this might be considered as a potential warranty claim ?
    Was the mounting bracket used? Biggest cause of failure is snapping the bracket onto the lens which breaks the internal seal.
    Name:  2016-03-15 Improper bracket mounting.jpg
    modsl55amg (04-05-2017)
  5. #14
    No bracket..double sided tape along top plane
  6. #15
    Quote Originally Posted by Nanook View Post
    Does your car wash use a power washer?
  7. #16
    It alerted the one time it was first noticed not present by the CPU then never again. I had to test to find it was toast
    You could miss the fail warning and never know a sensor was gone..at least for me this time
    When the cable failed last year it constantly alerted randomly but that may have been due to it working sporadically...not sure but regardless it may be a good idea to test every now and then
    thats very interesting as i had a similar issue not showing on the sensor check, but the same sensor worked testing with a laser a tester but no show in parking mode
  8. #17
    Product is long out of warranty but who is your distributor? We offer our customers that have expired warranties a reduced price replacement at $149.95 shipped with core return.
  9. The Following 4 Users Say Thank You to BestRadarDetectors For This Useful Post:
    64pvolvo1800 (05-15-2017), dinkydi (04-05-2017), Holla (08-16-2017), modsl55amg (04-05-2017)
  10. #18
    Sure..I take it though touchless washes and have a Karcher that I use with foam canon at home..but also avoid direct intense spray at the sensors..I understand they are somewhat vulnerable but they also must withstand "reasonable" moisture exposure
  11. #19
    KPMH...already sent a note...no reply yet
  12. #20
    does this diagram come with the new units , looks a very important set of instructions
