I think this failure was caused by water from a recent car wash I did...I recall concentrating the spray from the want in that area...soon I will rear the sensor apart and have a look inside
• '13 ML63 AMG - ALP 5 / STiR+ • '09 ZR1 - ALP 4 / V1 • '14 LEXUS RX350 - 9500ix • '14 HONDA CIVIC EX 9500ix • '16 TOYOTA RAV4 LTD 9500ix / ALP rear x 2 • '14 PORSCHE TURBO S ALP 5 /NET RADAR / STINGER / BLACKVUE
Okay to here is the results..it's clear the weather sealing failed..
This is a 4 year in service rear mounted sensor..that from the appearance depicts moisture infiltrating through the lower face/case seam. I do not know if the current units are fabricated the same or if this particular sensor has failed do to a manufacturing defect or design issue...I suppose time will tell if the others follow suit..I'm wondering if this might be considered as a potential warranty claim ?
Was the mounting bracket used? Biggest cause of failure is snapping the bracket onto the lens which breaks the internal seal.
modsl55amg (04-05-2017)
No bracket..double sided tape along top plane
Product is long out of warranty but who is your distributor? We offer our customers that have expired warranties a reduced price replacement at $149.95 shipped with core return.
64pvolvo1800 (05-15-2017), dinkydi (04-05-2017), Holla (08-16-2017), modsl55amg (04-05-2017)
Sure..I take it though touchless washes and have a Karcher that I use with foam canon at home..but also avoid direct intense spray at the sensors..I understand they are somewhat vulnerable but they also must withstand "reasonable" moisture exposure
