Quote Originally Posted by Rocketman59 View Post
Thanks, That worked great. Now to test my system with a couple of LIDAR guns.
Glad to hear everything went well for you. By performing the downloading of the Stats file after you perform the loading of new firmware, you will be able to see and confirm exactly what firmware version is in your ALP system, as well as the CPU hardware version, etc. And, by downloading the Config file, you will be able to visually see and confirm all of the settings you have selected for your Profiles (A, B, C) if you use the Profiles. Too bad we don't live closer to each other, as I would offer to "shoot" your system and test them for you.
