Results 1 to 8 of 8
Thread: Error 2
    Feb 2014
    Gold Coast Australia
    Error 2
    Hi
    I have for a while been getting inconsistent Radar cable not connected error messages though 98% of time, when I go through know K band areas, it alerts.
    Now I'm suddenly getting Error2 check cable,or not connected message and constant Error 2 warning non stop.
    Is there something I can check eg if I unplug one sensor, reset system amd repeat to see if it is indeed a sensor?
    I would assume if this would not work it is highly unlikely a sensor or cable issue and a controller issue, would I be correct in that assumption ?
    Or is there something else I can check
    Thanks
    Senior Member radargeek's Avatar
    Jan 2014
    York, SC
    Unplug one sensor at a time until the Error 2 goes away. You'll get a warning about a disconnected sensor, but the system will boot up and work.
    Once you figure out which sensor it is, inspect the wiring to make sure it isn't getting rubbed through or pinched somewhere.
    If I passed you on the right, YOU are in the wrong lane!
    2016 Encounters/Saves (to date): 33.8: 1/1 (last 4/13) | 34.7: 1/1 (last 3/11) | 35.5: 19/11 (last 8/28) | K: 1/1 (last 6/26)
    2015 Encounters/Saves: 33.8: 1/0 | 34.7: 13/4 | 35.5: 19/10 | K: 4/1 | LIDAR (sighted/hit with/save): 4/1/1
    ACTIVE CMs: Redline X, K, Ka 2,4,5,8 (highway/long trip RD) | New! V1C 3.8945 K, Ka CS, TMF2 w/YaV1 (in-town RD) | ALP Quad | BlackVue DR650GW-2CH
  3. The Following User Says Thank You to radargeek For This Useful Post:
    Abarth695 (08-30-2016)
  4. #3
    Senior Member Nanook's Avatar
    Apr 2014
    I think there is an issue lurking here somewhere...why all of a sudden are so many individuals experiencing possible sensor issues ?..I still get random start up alerts...sometime they go away..the first time I thought I had it narrow to a front middle sensor...then after unplugging it it went away..I did a general reset and plugged it in and all was good until I had to do the same thing with a rear...then all worked for a few days and today I got an error and rebooted 3 time and it went away...something is not adding up here..
    • '13 ML63 AMG - ALP 5 / STiR+ • '09 ZR1 - ALP 4 / V1 • '14 LEXUS RX350 - 9500ix • '14 HONDA CIVIC EX 9500ix • '16 TOYOTA RAV4 LTD 9500ix / ALP rear x 2 • '14 PORSCHE TURBO S ALP 5 /NET RADAR / STINGER / BLACKVUE
  5. #4
    Member nrgetic's Avatar
    Feb 2016
    Europe
    Same here from time to time I get a short Error 2 warning. After a couple of seconds it goes away and all back to normal
    Gesendet von iPhone mit Tapatalk
    Stinger VIP
    ALP Dual
  6. #5
    Error 2 = Sensor Interference
    It is normal to get an error 2 a few times a month. If the error is consistent is when we have to start to look at a sensor failing which would be throwing off its own interference. Sun, A Laser Equipped Vehicle, Even being too close to an object during startup can throw off an interference error when the system is testing all the transmitters and receivers during the self check.
  7. #6
    Feb 2014
    Thanks guys
    Here is my config below.
    I noticed that the unit can't find the firmware and whatever the other information above or below that line is i.e., the thumbwheels keeps turning. Does this mean anything. It won't allow my to reset either and changing heads over in different ports does nothing as well. Would be highly unlikely that both heads wiring or sensors would fail at same time!
    I think i need to send controller back for checking
    Serial number 2635193
    CPU Hardware version 1
    Firmware version 5.2.6
    Region Australia & Pacific
    Power Cycles 4472
    Control Set FW version 0.0
    Control Set HW version ALPConnect BT
    Activated locks not active
    Hardware version 1
  8. #7
    Apr 2014
    Is it possible to regress to an earlier f/w ? (curious to see if things straighten out)
    edit ..Had to edit this senseless question
  9. #8
    Quote Originally Posted by Abarth695 View Post
    Thanks guys
    Power Cycles 4472
    Hardware version 1
    Try this... Disconnect one sensor at a time and see when the error stops.
