Current CM's installed AntiLaser AL Priority; Radar Stinger VIP front & rear MPHD antenna,
Retired and sold CM's Beltronics remote XRC+; Surespotter Ls-101; Cheetah C50:
Testing equipment Laser Stalker laser LZ-1,ultralyte lti 20/20 compact, Radar testing Falcon HR Kband & Stalker Dual SL KA34.7 & Stalker ATR+ Vintage Kustom signals KR-SP10 K 24.150,5watt UHF radio GME TX 31000VP. 50watt Waccom 400MHZ 480MHz cheetah C550 Dash camera Cowan Aw2. Thinkware H50, ( If it didn't capture it it's a Thinkware!)
May have a revelation..First I removed the BT ver:1 module that I never really used...then I did a complete reconfigure removing all sensors and re-inserting each in their home location one at a time doing a re-learn reboot each time..and each time got a clean boot..and finally with the BT gone all seems okay...did possibly the upgrade to the last latest f/w 5.2.6 possibly cause a conflict with the BT module ver:1 ????
After several power off and reboots without the BT module in the works everything appears okay...fingers crossed !!
• '13 ML63 AMG - ALP 5 / STiR+ • '09 ZR1 - ALP 4 / V1 • '14 LEXUS RX350 - 9500ix • '14 HONDA CIVIC EX 9500ix • '16 TOYOTA RAV4 LTD 9500ix / ALP rear x 2 • '14 PORSCHE TURBO S ALP 5 /NET RADAR / STINGER / BLACKVUE
Question..what is the alert if the power level is deficient or inadequate...does the control box alert to this ?...
Dayum...I think this whole episode may be battery/power level related...do you know what the alert is from the control unit ?
Hmmm..doesn't sound like it but I thank-you for this..it's so odd because it only does it some of the time..gotta do more trouble shooting
dinkydi (09-13-2016), winterbrew (09-12-2016)
yep does the same with me the low battery power , must have a sensitive voltage warning threshold
If you run with control box what type of code alert do you get ? TIA
winterbrew answered your question in Post #16...
...so I'm confused why you're asking again.
Do you have 2 different AL-P sys b/c of 2 vehicles ?
1. Basic Control Set (non HiFi) - ERRORs:*
LED constant red + 1 beep:
Error 1; low voltage, check vehicle power supply
2. HiFi Control Set:
* If you are using a HiFi Control Set w/ an exterior speaker, instead of error and warning tones you will hear descriptive information for each specific error.
