Quote Originally Posted by Nanook View Post
Well if appears the issue is still active..one connector..that same wire of which I replaced the sensor is still giving a fault..except when I plug it to a front socket (it's a rear sensor) don't know what the hell is going on
Sent from my iPad using Tapatalk
Interesting to know what may be the cause to the bum sensor?
> Have you washed your car with high pressure hose?
> Have you used a Laser interceptor remote or other kind remote to test your unit?
> Have you shot a laser gun too close to sensor?
