Results 1 to 10 of 17
  1. #3
    thankyou for the reply citrus.
    Well my BT arrives today so I will be able to check, my MCU firmware revision is MTCC KDL6 2.97, and I can't seems to find much information on it.
    From what i understand the MCU sets the make of BT under the factory menu, mine was set to WQ_BC6 and I change it too WQ_BC6S and it seems to allow ALP to power on the BT and scan ONCE, will find out today if it actually picks it up.
    I seem to remember seeing on XDA something about a BT list, and they had issues with the picking up those OBDII adapters because the name was not in the list, seems the have a table and if the name is not on it, it will not connect.
    I have been very tempted to try Malaysk, but I will wait, Eonon said they will look into it, and they seems to be active on a couple of forums so I might direct them to here and XDA, they are unaware of any BT issues.
    What flavour of unit is yours? They all seem to be the same.
    Might pay to flick a donation to Malaysk and just add a note 'could u please' add ALP to BT, cause that was my plan if Eonon could not get it to work
