@lamster
1.Do you have Basic "Control Set" or HiFi version ?
2.Are you using Thumb Drive version USB 2.0(ONLY) & 8 or 16Gb
@lamster
While I've really wanted to help you resolved your problems, I just can't work w/ you any longer. I've asked you a number of times specific questions, all I ever get from you are partial answers or complete avoidance to specific inquiry & you've worn out my limited patience. If you take some time to look/read the "Sticky Threads" in the AntiLaser Section on the "how to do's" of getting the system up & programmed correctly,it may help. I seem to remember that you cannot have "Profile" (which I see in your Stats listing) unless you have the HiFi option, last I remember this feature is not permitted w/ the Basic Control Set pad(& why I asked what you had)...I'll admit this may have been changed over time by AL & I just missed its add-on(to Basic Control Set) now.
It could be you have a duality of problems like bad Sensors + faulty f/w in either/both the Control Set & the Control Box. I do know that it was recommended by BRD/AL that users should not use 32Gb Thumb Drives. (I use SanDisk 'Cruzer' 8 or 16Gb USB 2.0 Flash Drives & have never had a problem). Perhaps just using the 1 good Sensor you're sure is good in the F1 slot while trying a different USB Drive of appropriate capacity & a fresh download from the ALupdate website might help.
I'm off the Forum for a while to TCB & wish you good luck w/ efforts to fix your install problems.
Thanks for your effort, i did answer all of your questions so i am not sure what you are referring to. I did not set up any profile, alp automatically have profile a,b,c. I followed all the steps from the sticky threat. Even after factory reset and reloading the config, again profile a,b,c appears.
I never heard that it is recommended to use a 8gb or 16gb usb drive, i figured it would not make any difference...
If i missed anything please let me know
may be have a clean start,back to basics with std controller, just use the two outer sensors f1/f2, do a factory reset, as on page 11 can be confusing a little, also a manual check on page 12 if need to,fw up grade for controller, and then cpu, ,then set up, all one at a time,
car outside display green, gps lock display yellow, above speed gps setting goes over to blue
@lampster
First, the alp stays in parking mode only until i walk past both sensors. I must walk past both sensors in order for it to go into defense mode(blue led).( should stay in parking mode)
@lamster
Do you now get the point of why I accuse you of not answering questions ? - Yes, I can be a lil anal about things, but that's my nature & I'm not going to change for you or anyone else.
@RedRocket, sorry i did miss some of your questions and thank you for your help. I appreciate all your effort and support.
I live in buffalo NY and yes the drive way is next to a chain fence, shared drive way. For the control set, i answered in post #22, I'm using the basic control set and thats the firmware i downloaded.
I received a replacement head and plugged that head into the driver side and works perfectly. It seems like its a head error, most likely a pinched wire. The sensor head wire might have been pinched from the bumper.
I'll take a picture of my setup wiring tomorrow, and maybe i can get some input on my wiring?
curmudgeon (06-10-2016)
Whaddya know, born n' raised there myself. Congrats on solving your problems !
I visit there once in a while & do have some requests from other members here on the Forum for Testing in the area (which I also do). If you're active here & participate maybe the locals might extend an invitation to an event...time will tell. There is nothing planned at the present time though,AFAIK.
curmudgeon (06-10-2016), lamster (06-11-2016)
