Results 1 to 8 of 8
    Member gapi's Avatar
    Mar 2016
    Audio Disabled in Other Apk's When ALP is Running on Bluetooth
    My device is a Nexus 5x.
    I am running the Bluetooth module and the control set is connected also.
    When the ALP apk runs on Bluetooth I cannot get audio to playback in other apks. Music Player, UTube Videos, nothing will play back audio but for the ALP apk.
    So I kill the ALP apk and it does not reverse. I have to reboot the phone.
    The Bluetooth icon looks different when ALP is running.
    Thanks
    Unplug the power cord. I assume you are using Apple and for some reason when you connect a power cable and have bluetooth enabled Apple wants to route all audio through BT, Try unplugging the power cord and see if all returns to normal.
    Mar 2016
    Thanks,
    No, I run a Nexus 5x, heh, the first sentence in my post. Now I don't feel so bad. ;-)
    I did not have a power cord connected but will go down and try it just to see now.
    Lemme know.
    Mar 2016
    Still the same. No difference with power connection or battery powered.
    I did change the Audio Route setting and that's not good either. In "DEFAULT" nothing works.
    The Demo is mute and no music player and the like playback. In "ALL" at least the demo and system alerts will play.
    Thanks
    Mar 2016
    Question About the Remote LED Setup
    It doesn't say so I have to ask, I hope I did not miss it.
    If I have a config to alert and defend for Laser and have the LED set to Dark Mode, or even very Dim, with a laser alert still be full brightness?
  6. #6
    may be best to read through the forum on the bt alp, i would forget bt atm and just run as std,by going bak to start page factory settings etc , and getting the system operating correctly, and updating every thing, best to take ur time, then going over to bt, and the correct app on phone
  7. #7
    Mar 2016
    I think I found out whats going on.
    When the ALP is active the phone shows a BT Headset is connected and no media is output to the speakers.
    The opposite when the ALP System is off.
    The screenshot shows how I found it while looking into my volume control apk. Note the BT icon state change in the status bar when ALP is active.
    I don't own a BT headset.
    I'm going to call him tomorrow to let him know. Maybe its just my phone IDK?
  8. #8
    Mar 2016
    Going to call Monday and request an exchange for the BTM to the HiFi. The BTM just doesn't want to play nice with my system.
    I cannot use my hands free calling either. I just need to get it out of the picture.
    I guess he has been on Vacation or something this week.
