I hope that AL website is updated so that we can load in an old CONFIG.ALP file and it will set all of the parameters to their old values, and any new parameters can either be set to a default value or flagged so that the user can choose, then can successfully generate a new file. When I tried this in the past, it could load in an old file, but once it had done so, if the file was NOT in the same format (was of a previous revision), it wouldn't successfully generate a new file. This is especially important now that we have 3 profiles per file. With so many parameters to set, it's extremely easy to overlook something and the only way I can ensure that everything is set properly is to open two browser tabs and click back and forth to make sure everything is exactly the same. As you can imagine, doing this 3 times for 3 profiles leaves a lot of room to screw something up.
