Results 1 to 10 of 23
  1. #4
    BRD: What you have suggested that I do, is exactly what I did.
    A properly formatted USB flash drive contained only the three new Profiles.
    I inserted the flash drive into system of car 1, loaded the system, turned system off, then turned system on. All OK on that system.
    I then inserted the exact same flash drive into car 2, a few minutes later, loaded the system, turned system off, then turned system on. Anomalies existed.
    I then took another properly formatted flash drive and downloaded a Statistics and Use file from Car 1's system. All settings correct, per printout.
    I then formatted that flash drive and downloaded a Statistics and Use file from Car 2's system. Anomalies were shown on the printout.
    I compared the printout from Car 2, to the printout from Car 1, and from the printouts of the three Configuration Profiles that I had originally generated.
    Printout from Car 1 was identical to printouts of the three original Profiles I selected.
    Printout from Car 2 had anomalies from printout of Car 1 and the printout of the three original Profiles I selected.
    Even without the printout from Car 2's system, I could see that there were discrepencies between the Profiles I generated and what was in Car 2's system.
    BRD, I have not yet done so, but, if I manually change a setting in a particular Profile, say Profile A, does the manually changed setting only pertain to Profile A, or will the manual change also affect the same setting in Profile B and Profile C?
    Thanks!
    Insert the config file let it load and then turn it off and back on and you will be fine.
    modsl55amg (01-15-2016)
